Thread: Ketch rig
Old 08-23-2001
JeffH
Posts: n/a
Ketch rig
Mizzen staysail are flown on reaches. They typcially have a halyard at the forward top of the Mizzenmast and their tack is lead to the deck about even with the base of the main mast. They are rigged in a number of ways but typically they are attached to a pad eye to weather of the mast base on the deck or even at the rail. Occasionally you see their tacks rigged to a pad eye at the base of the mast or to the genoa sheet tracks. They typically have a single sheet that is usually lead to snatch block on the deck near the leeward corner of the transom.
The sail is flown on longish reaches and is dropped and raised on each jibe since sail prevents the mainsail from beingable to jibe. These are real workhorse sails adding a lot of speed in the right conditions. Try it, you''ll like it.
