SailNet Community - View Single Post - Cal 33-2 Tender?
post #8 of Old 11-06-2010
ashmun
The Cal 33-2 has a sail area/displacement ratio of I believe 18.08, so consider using a working jib (i.e. something under 100%) to start. Putting one reefing the main is okay but might be challenging if you do not have a reefing system or not used to reefing. I’m assuming you don’t have a furling system. I’ve owned two Cals (2-30 and T/4 designed by Lapworth) and found them both to be a lot of fun. I single handed by T/4 (24’) for twenty years before moving up to the 30’ which I owned for 7 years before deciding to move up to a 38’.
ashmun is offline
