SailNet Community - View Single Post - GPS / ChartPlotters; Totally Baffled
post #5 of Old 11-13-2010
Gene T
Gene T's Avatar
I sailed for years without because they were unavailable (years ago) or too expensive. Then I got a Garmin hand held that I used for years on several boats. Worked great. The new boat has a Raymarine Color Radar/chart plotter that is almost impossible to use but has lots of features. Yes it displays more info but I seem to spend more time fiddling with it than should be needed.
The newer units are simpler to use, the older Raymarine I now have requires going to the manual frequently just for simple stuff. The learning curve is high. Garmin has a much better user interface.
A hand held and some paper charts is more than anybody needs. More than that is just stuff to play with, not that it isn't useful at times. A hand held will show you where you are, and you can put in waypoints for harbor entrances which is very handy in the fog. It will not get you past a point however because the maps are not that accurate. Neither is depth.
I also used a $100 fishfinder on the last boat with the puck glued to the inside of the hull. That worked great and actually shows you more about the bottom that a regular depth sounder.
Gene
Currently in Long Beach, CA
Gene T is offline
