SailNet Community - View Single Post - Slightly unorthodox anchoring technique
post #1 of Old 07-07-2006 Thread Starter
Iraklis
Hi everyone,
My (possibly wrong) intuition tells me that the best way for an anchor to set is the following: after the initial tug, let out all the rode you can, and then motor in reverse. This will keep the anchor most parallel to the sea floor & should allow it to set better. Afterwards, you can reduce to whatever scope you'd normally use.
My thinking goes as follows: unless you do this, the force that will dislodge the anchor at its final scope (e.g. 7:1) will be the same as the maximum force you can use when motoring backwards. Using e.g. 10:1 just at the "setting" phase should allow you to bury it even more. I'm not saying that this will make 7:1 work just like 10:1 - all I'm saying is that this would bury the anchor deeper, which should be a good thing. This would probably hold true for any anchor that requires you to motor backwards.
I am familiar with the "proper" way to do this. However, I only suggested this as an idea and my sailing instructor almost failed my ASA bareboat certification (I guess he took it as a statement instead of a question). Obviously, there are situations (e.g. med mooring) where you can't do this. But can any saltier SailNet member think of something wrong with this approach?
Thanks,
Iraklis
Iraklis is offline
