SailNet Community - View Single Post - Slightly unorthodox anchoring technique
post #2 of Old 07-07-2006
sailingdog
I can see some potential issues with doing it this way.
The first being, if you're on an all chain rode, not being able to apply enough force on the anchor to actually get it to set properly. Most sailboat auxiliary engines are not powerful enough to set a long length of chain rode, as most are a bit underpowered as it is.
The second being that many anchorages don't have enough room to do it this way, and if you get in this habit, you will find that in an emergency, where you default to what you know best, you'll get screwed over pretty badly.
Those are the two that jump out immediately to me... but there are probably some other fairly serious reasons not to learn to do this as a default.
sailingdog is offline
