SailNet Community - View Single Post - What boat is this?
post #18 of Old 11-15-2010 Thread Starter
This great boat was sold last year. I wanted to buy this boat and didn't have the money or the courage to move and buy it. I am glad to have found the add from the listing and here is the information that was included about this prized boat.
28' Norrland
Year: 1969
Current Price: $20,000USD
Hull Material: Fiberglass
Engine/Fuel Type: Single Diesel
YW# 66791-1407220
Many Pictures Available, Please go to ROSA SALVAJE (ROsa SAlVaje) | MySpace
Thisboat is a well designed, well built, full keel, double ended Swedish sea boat.
The hull is braced by four full length box stringers. The hull and deck is epoxyglued and triple tabbed for and aft, resulting in a one one-piecefiberglass unit. No mechanicalfasteners are present to allow water leaks into the interior. ROSA SALVAHE is a dry boat.
Forward,she has a watertight, collision bulkhead which is part of her anchor stowagesystem. She stows two large anchorson a teak and stainless steel anchor roller, secured but ready for immediatedeployment. Large opening foredeckhatch gives access to a space that will contain three anchor rodes of over 120feet each plus space for a third anchor.
She has a vinyl covered double stainlesssteel life lines, tall stanchions, with bases that are thru bolted, braced andbacked up. The aluminum mast iskeel-stepped and rigged with oversized wires and turnbuckles. Stay locks are used for easy replacementof rigging.
Noexpense has been spared on this vessel to prepare and constantly upgrade herfor extended cruising and deep sea sailing. She has sailed more than ten thousandmiles in seventeen years under the command of the present owner who lived aboardher full time. ROSA SALVAJE is aserious ‘blue water’ boat, giving a good turn of speed producing120 mile days with a comfortable ride. She will take you the maximum distance at a minimum cost. She is not a fixer-upper but rather arare find for the serious couple looking to enjoy the cruise of a lifetime.
Theforward bulkhead is collision watertight. It holds the anchor locker that has the capacity to hold the 120’lines and 30’ of chain for two large anchors and a third spare anchor. The teak anchor roller stows the twoanchors and compartments under the cockpit seats holds two fender boards andone large pneumatic rubber fender. Lazarette compartment holds four dock lines of twenty-fiveeach.
2004Yanmar 1 G M 10 horsepower, new flex coupling,stainless steel shaft, stuffing box, cutlass bearing, muffler, shifter, cables,sea strainer and seacock inlet. Included is also a Parts Number book, servicemanual and installation manual.
Theengine room is insulated with 1 ½ high grade silvery Mylar foam soundshielding that covers the entire room, including the overhead. The engine has easy access whileunderway by simply opening the double dogged door located in the cabin. Access to engine can also be made byremoval of the hatch type cockpit sole. No pumps are required for oil change. It will drain from the pan. It uses two quarts of oil per change. It uses one part fuel per hour at 3,000RPM at speed of 5.5 Knots.
1- Mailsail; custom made with heavy cloth and stitching
2- StormTri-Sail with separate track on mast
3- HeavyStorm Jib
4- BladeJib
5- #3Sail
6- Light#3 Sail
7- RipStop Reacher
8- Spinnakerin Sally
9- #1Genoa
SILAB reefing- Hank on Sails
New,made in Trinidad
1- Permanentlymounted “TREM” aluminum radar reflector
2- AQUAsignal Tri-color Mast Head Lights. Series 40
3- WINDEX15 masthead wind indicator. (can be seen plainly at night when Aqua signal light is inthe “on” position.
4- Doublelife lines with S/S bow and stern pulpits
5- StandardGate on Starboard side
6- Stainlesssteel swim ladder with side boarding platform for easy access from dinghy
7- SpecialTREDMASTER non-skid covering on main decks
8- Twooutside viewing compasses
9- JimBuoy man-overboard-pole with quick release mounting
10- 7 winches– three winch handles
11- Spinnakerpole
12- Custompadded helmsman’s seat for traveling on the ICW or day sailing.
1- AMshort wave receiver with wire antenna
2- Raymarine S T 2000 Tiller pilot
3- StandardMST 65 Deluxe am-fm Cassette stereo with four speeds
4- Garmin GPS map 162 with external antenna
5- StandardGALAXY GX23005 VHF radio with masthead antenna
6- StandardS L 40 Speed log
7- StandardHorizon D S 40 digital depth sounder
8- Avelco XCD 550 Fish Finder with 600’ depth, log andspeed
9- StandardA S 45 Analog self-powered Speed instrument
10- Small powerconverter (for computer use)
11- “Calterm” alternator and battery voltage analyzer
12- Spare depthgage, knot meter, and log
13- Manual Booksfor AM electronics
14- Simplified12 volt electronic wiring system with USCG approved “tinned”oversized wiring. All panels with on-off switching. All circuits fused with spare fuses forall circuits.
1- Specialdesign, extra insulated ICE BOX with clean cold H20 dispenser for drinkingwater. Block ice will keep for 7days.
2- TwoGUSHER hand 1 ½” high capacity bilge pumps mounted in Bow andcockpit… can steer and pump from helm position.
3- Canvasquick release cover at helm station.
4- Electronicbilge pumps (one medium capacity, and one high capacity with automatic switchplus spare switch.)
5- 48individual storage spaces
6- Newteak cabin sol from Trinidad
7- Customcabinet work from Trinidad
8- Oversizedbronze dead bolts on all opening cabinet drawers
9- Teakdrop-leaf dining table: seats six or side leaf opens for two.
10- Largedouble bunk for a couple
11- Pilot berthwith Lee Cloth for use underway
12- Two 12volthigh efficient, low draw HELOS fans
13- Doublebulb, high output, low draw florescent lights. Spare two-bulb light.
14- Mosquitoand no-see-um screens for all hatches with easy stowing.
15- Fiveopening double gasket, solid frame hatches for Florida ventilation.
16- S/Sgimbaled two burner stove with large oven with spare burners.
Displays a full sized chart andcontains a large chart storage area.
Custommade. One for Dive gear andmiscellaneous items, the second for fuel jugs. Included are jukes for gas and diesel.
GAS TANKS for cooking stove
Twoaluminum tanks, new style, safety mounted in cockpit that can be turned offfrom the galley.
Stainlesssteel Diesel will straight fill for “dipping the tank”. Also there is a sight glass to monitorfuel amount while underway, with a shut-off valve.
The Solar panel is installed onoutboard stainless steel bracket that allows for maximum angle to the sun,producing high output with switches to distribute voltage to two shipbatteries. ModelKYOCERA 51watt.
NORUIK6 yachtsman, RORC approved (certification # 11837) life raft: two man capacitywith canopy, automatic inflation with emergency water repair kit held in a softbag. It has special stowage underthe companionway step, designed for quick deployment. Stored under cabinsteps for quick removal.
Custom made, fiberglass 9’ two-piece cup styledinghy. Storage at sea on custommade rack over cabin area. Yamaha 2horse power motor purchased Nov 2003 and received lower end gear oilchange. One gallon gas can withfilter.
travelnodes is offline
