New name (I know, I know)
Here is one prior string on the subject: It began with a fellow questioning why we stick to superstitions in the 21st century.
In Reply to: Superstition be damned.
I''m not sure I get your point but it is clear to me that must be right that there is no place for silly superstitions. Now ritual which has definite cause and effect you must respect. Take the one about changing the name of a boat. I am sure this is just coincidence but of the twenty plus some boats owned by myself and my family, we only changed the name of three, that was the two that lost their masts and the one that was sunk on the rocks at Fort Toten. Not a large scientific sampling mind you, but a 100% correlation sounds like cause and effect to me. I don''t believe in superstition only what can be proven by scientific method. I am glad you are willing to continue our testing where we left off. Bravo, my brave man.
Jeff (Think he bought that?)
With you all the way...at a safe distance! Posted by ACB on July 08, 1998 at 23:23:10:
It''s a funny thing, but I have spent my life in commercial shipping and
while we do have to rename ships we are a deeply superstitious lot!
Actually, superstition has a sort of place in keeping up morale; if you
have complied with all the superstitions you feel better, and are
perhaps likely to perform better. We should know the physics of sailing
well enough by now, but the tired human brain after a few days at sea
needs all the support it can get!
Reply to: If you don''t believe in senseless superstitions, why name a boat at all?
Perhaps it is my fault that my point did not come through, since I gave the posting a somewhat inflammatory title. I certainly was not slamming "respect and celebration of the world around us". I was making a much more focused point. I was trying to say that we should not be bound by practices which no longer make sense (see me examples re departure date and hull color). Particularly when these practices are in lieu of proper seamanship. As to your specific points, I am sure you would agree that something failed which resulted in those rigs coming down, and there is nothing mystical about things failing on sailboats. My rudder did not fall off because of bad Feng Shui. The pin ate through the wood after swinging back and forth for 15 years. Also, I understand and agree with your point about boats having a personality, but of course the original name did not have the benefit of those years of experience in naming the boat. Why not give the boat a name that captures its essence PLUS your relationship to it. This is why I am waiting to put my hew boat''s name on the transom until I am sure it fits. Of course, a name also has many practical advantages, as an aide in hailing, recognizing friends out cruising, etc.
And I suppose, next you''re going to tell me that whistling doesn''t affect the wind strength! Posted by Jeff H
Of course the fact that you changed the name of your boat had nothing to do with the fact that your rudder functioned perfectly for 15 years but chose to break after you changed the name of the boat. The fact that it broke clearly PROVES nothing at all. I think it is important that you keep testing. We all admire your bravery. And I suppose next your going to tell me that whistling doesn''t affect the wind strength! After 37 years of testing and noting a direct correlation between wind speed and whistling, for me, I think that "superstition" has been proven to be actual scientific fact. I have tested this many times. Whenever I whistle on board the wind eventually increases in velocity. OK, so it doesn''t happen immediately but sooner or later the winds increase. Ok, maybe it is a few days later, but it still works! Keep up the good work!
(For those of you who are about to have me locked up, I want to point out that to some extent my comments on this are meant to be a bit tongue in cheek but only a bit.)
Posted by Evelyn Keller on June 04, 1998 at 07:26:12:
I am looking for information, or a source or reference, where I can find out how to perform a ceremony (some suggested words to say & actions to take) to rename a boat formerly owned by someone else. A couple of years ago, there was a short item in Cruising World magazine that described a ceremony, or some kind of protocol, to use when you want to rename a boat. I haven''t been able to locate that item. We certainly don''t want to do anything to displease the gods of the sea or any other concerned gods--but we''re about to purchase a used boat and want to put "our name" on it. I''d appreciate information from those who may have done this before, or the date, page number where I can find this information.
Posted by Jason on June 10, 1998 at 12:57:47:
If you have already bought the boat, it''s too late! However, if you buy the boat without a name (have the current owner take her name off, and sell her without a name) you are free to name her whatever you wish. best of luck!
Jason
Posted by Carl Miller on June 05, 1998 at 05:40:24:
In a spirit of cooperation with the Name Gods, I would offer the following technique in renaming a boat:
An alternate method involves scraping off the old name and painting on the new name. However, first it is recommended that you empty the contents (internally of course) of a good 200-yr. old+ "Jose Cuervo" or "Sauza" Tequila.
This process cleanses the soul and prepares the boat for a proper skipper!
Then, there is plan "B" discovered ages ago by the Vikings. It will permanently remove the old name without the use of paint removers, putty knives, heat guns, but does employ the use of natural elements. This requires the flame as a result of natural lightning. One may arrest the Fire Gods thru the use of a torch. In the 2nd and final stage of the cleansing, one simply burns the sucker down to the water line and sets the boat adrift in a quiet place of your own choosing. There is an upside to the endeavor....it also removes stuff from those dark corners of the lockers, eliminates those old unsightly PFD''s that are never thrown away, and at the same time, stains on the decks disappear forever.
p.s. the yellow stuff with a worm is probably Mescal not Tequila. Salud amigos!
Posted by ACB on June 05, 1998 at 01:51:07:
I am extremely superstitious about boats; the result of long experience. Re-naming a boat is a BAD IDEA and will certainly lead to trouble; better buy a different boat. Never paint a boat green or disaster will ensue (I know this to be true - bought a green painted boat, did not rename her but thought I would get through the first season without a repaint - lost rudder in North Sea.) Never start a cruise on a Friday. Never EVEN MENTION the long eared fellow on a boat and with due respect to Bob G I would advise against using the foot of the animal in any ceremony close to a boat. All Christian priests of whatever persuasion should be carefully avoided in any ceremonies to do with boats.
If you MUST do it, I have found during a career in merchant shipping in Asia that Shinto priests are capable of performing the renaming ceremony without ill-effects, and that a visit by a Feng Shui practitioner usually gets rid of residual ill-luck. If you cannot manage this them at least pour a libation to Tin Hau, the Taoist Queen of Heaven, who takes a special interest in small boats.
This is a true story. Two cargo passenger ships were built to run between Japan, Hong Kong and Australia. One was a perfect ship and nothing went wrong. The twin sister went aground twice (expensively, on Japanese oyster beds!) The Hong Kong crew demanded a Feng Shui man or they would not sail. He came on board and located the source of the trouble. In an alcove in the first class smoking room was an antique statue of the Buddha. He pronounced that this was a "land Buddha" and was always trying to get ashore, hence the groundings. No problem - he had a solution. He removed the rather expensive statue and reappeared with a very cheap and nasty one which he pronounced was a "sea Buddha" and installed in the alcove. The ship ran for the next 20 years with no more trouble!
Posted by ray on June 04, 1998 at 17:12:12:
Check out the 48 North (PNW magazine) web site. They have a "Boat De-naming Ceremony" that you can down load and use. The author finds it critical that you "de-name" the boat correctly or you are in deep .... It''s all in good fun however, for the those who are not sure about the sea gods that live below us, it will give''em peace of mind. Remember that the primary purpose of a de-naming ceremony is "another excuse to party" so have a good one for the CW BBS crew.
Posted by Jeff R on June 04, 1998 at 15:15:01:
My wife has been wanting to rename our boat since we bought it, 3 years ago. I really don''t care. I had heard something about not doing it until the boat has run aground 3 times, I did not know that was a power boat requirement. Unfortunately, we have bounced off the bottom 3 times (not really hard aground, but did damage the keel). So that excuse is gone. Will the gods be more upset if you rename the boat after sailing her with her old name than if you renamed it right away? Also, if you are supposed to eliminate all references to the old boat name, what about postings about her on the net? There is no way I could ever eliminated every reference to her name in all the places I have posted it. Fortunately my wife still has not picked a new name, so this may never be an issue.
This is EXACTLY what you must do
Posted by tomC on June 04, 1998 at 08:50:11:
Here it is, from the Fishmeal FAQ:
Yes, there *is* a way to change a boat''s name without upsetting the various deities of the sea and air. First time out with the new name on the boat, luff up into the wind and drift to a complete stop, then allow the boat to sail backwards. This represents "backing over" the old name. Sailing backwards is hard -
requires a good breeze, some waves usually help, and a fair amount of skill. But the goddesses and gods that are concerned with these matters are not easy to impress! If the boat is a fin keel type with a separate rudder, you should be able to stabilize in backward mode and do it for at least a few boat lengths. For a full-keeler, the spirits will most likely be appeased with a half-boat length or so. Under no circumstance should you do this under power! If the boat is a powerboat, you will have bad luck with the new name until you have run aground three times. I don''t know if these can be intentional groundings - perhaps someone with more experience in this area could clarify this.
>>Originally from: fishmeal@netcom.com http://www.well.com/~pk/fishmeal.html
What I did
Posted by bp on June 04, 1998 at 08:15:31:
In Reply to: Ceremony to Rename a Boat posted by Evelyn Keller on June 04, 1998 at 07:26:12:
If the boat is on land walk around it counter clockwise three times, then remove all traces of the old name. Then you should never mention the old name again. If the boat is in the water, maybe swimming around it three times would be allowable. The important thing is to enjoy your new boat.
here''s what to do...
Posted by bernie on June 04, 1998 at 10:11:28:
hi evelyn,
here''s what to do. get lots of champagne, good appetizers, lots of KY jelly, go sailing with your favorite man, anchor somewhere beautiful out of the way and have the time of your life.
Bernie
A bit risky, this
Posted by harryj on June 05, 1998 at 07:21:13:
The problem is that you often end up with another crewmember and then have to get yet a new boat to have enough room for the little sucker, thus repeating the process. It is somewhat offset, however, by the fact that you will at some point be able to justify getting a Valiant 40. There is a tried and true method used here in Africa, (although not applicable in this case): sacrifice a virgin. Since the rules are a bit vague, you can usually figure out how to do this in a way acceptable to the sacrifice.
This works
Posted by S/V Triumph on June 04, 1998 at 10:31:46:
I used this plan published in 48 north http://www.48north.com/ to rename my Mason 43. If you follow it religiously you will satisfy all the gods.
The only safe way
Posted by Bob G on June 04, 1998 at 11:45:37:
Materials required:
2 bottles champagne (preferably imported, but domestic has been successfully used) 1 rabbit''s foot
1 red hair ( must be from a genuine redhead and must be exactly six inches long.
Procedure:
1.Wrap the red hair around rabbit''s foot.
2. Soak rabbit''s hair in champagne.
3. Rub soaked rabbit''s foot over old boat name (very vigorously)
4. Without turning around, throw rabbit''s foot over left shoulder into the sea. If boat is positioned where this can not be done, it is permissible to have a second person catch the rabbit''s foot in a bucket and run it to the sea.
5. Drink remainder of first bottle of champagne.
6. Apply new name to boat.
7.Have a boat christening ceremony, but DO NOT BREAK SECOND BOTTLE ONBOAT. Just sprinkle some on the new name and drink the rest.
8. Final step...most important! Go sailing and have a happy life.
But wait! There''s more!
Posted by Chuck Munson on June 04, 1998 at 12:31:01:
All of the fore-dated advice is good and accurate, as far as it goes. The primary omission was that ALL TRACES of the old name must be removed from all material on the boat. I know from sad experience that trouble will trouble you until you heed this advice. The dinghy that came with the boat in question had diminutive version of the mother ship''s former name. When a raftup buddy took his dog ashore in the aforementioned dinghy with another buddy''s outboard on the back, it sank out from under him as he was preparing to climb back aboard. He clung to the painter with one hand and the stern ladder with the other as the flotation foam bobbed to the surface, a puzzled look on his face. He finally let it go. The local Voltaire fire department divers could find neither trace of the dinghy, nor oil slick from the motor. Rum works as well as champagne, and is more traditional in some quarters. What ever your libation, be sure to give a glass to old King Neptune, or the name change might not take.
