SailNet Community - View Single Post - aft bilge access...?
post #1 of Old 11-16-2010 Thread Starter
GulfCoastPirate
Ok, I've got a newbie question. This is my first sailboat so there probably will be a few stupid questions from this end. Thanks in advance for yalls patience. (I do use the search function a lot)
A bit of background... I bought a 77 islander 28 and I need to replace the two transom thru-hull fittings (ventalation and exhaust), as well as the impeller on the water pump. the only entry path I can see is the port cockpit locker. Is that correct? Is there another way into the aft bilge? I'm a pretty big guy (6'0-250) and its a helluva tight squeeze.
Also, any recomendations/sources on an upgraded fitting to replace the (non) existing ones?
Thanks,
Kenny
GulfCoastPirate is offline
