SailNet Community - View Single Post - Fibreglass Deck Build
post #15 of Old 11-19-2010
Boasun
Boasun's Avatar
Just wanted to add:
Steel and fiber-glass are not a good mix. Especially after the boat has been in rough weather a time or two... The seams where the two materials join will probably open up.
If you do go with an under layer of plywood, Then use two layers of ply Each about 3/8 to a 1/2 inches thick. Ensure that the seams & butts over-lap of about half the width & Length of the plywoods. This two layer will strengthen the deck. Then you add your top layer.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
