SailNet Community - View Single Post - Yanmar 2GM20F, raw water pump
post #2 of Old 11-19-2010
JimsCAL
JimsCAL's Avatar
Could be wear in the pump housing not allowing a tight seal on the sides of the impeller. Look for scoring on the inside of the cover. Sometimes filing the cover smooth will fix the problem. Some covers can be "flipped" to use the smooth outer surface inside.
JimsCAL is offline
