SailNet Community - View Single Post - About to buy a N33 -- getting cold feet?
post #10 of Old 11-21-2010 Thread Starter
sailorpilot
Originally Posted by sailingfool View Post
Your difficulty with the strong breeze just sounds like getting used to it, most boats need a reef and a reduced jib as you get to 20 knots, and will become a handful if you have too much sail up. an i trust the seller wasn't on board to advise on boat handling?
He was on board, and suggested reefing the genoa, which as I said seemed to do the trick. I was only concerned about this because I had read this was a problem with Newports. I don't have enough experience to say if this is a common trait, and its only a matter of proper sail trimming. Seems like that's the case. We reefed the main as well a bit later, and the handling seemed fine, not a lot of heel, and making 6 knots in gusts to 25.
sailorpilot is offline
