PSS shaft system
Unless you are not telling us something else then leave well enough alone.
If you pull your shaft you may find that the packing in the stuffing box has worn the shaft at that point. If the "new" system must use any of that surface then it will not be full diameter.
Just change the stuffing box hose if it''s old and the packing. The old system works fine as far as I am concerned. If the hose is old then look at the cultlass brg. too.
