SailNet Community - View Single Post - This Websites Tutorial!
post #3 of Old 07-10-2006 Thread Starter
Send a message via MSN to D3AN
It opens oup for about 5 seconds then changes, this message appears on a white page :
Error Occurred While Processing Request
Error Diagnostic Information
Template file not found.
HTTP/1.0 404 Object Not Found
Note: If you wish to use an absolute template path (e.g. TEMPLATE="/mypath/index.cfm") with CFINCLUDE then you must create a mapping for the path using the ColdFusion Administrator.
Using relative paths (e.g. TEMPLATE="index.cfm" or TEMPLATE="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
The error occurred while processing an element with a general identifier of (CFINCLUDE), occupying document position (39:1) to (39:48) in the template file c:\html\sailnet\collections\learningtosail\get_plu gin.cfm.
Date/Time: 07/10/06 15:02:32
Browser: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.0.3705; Media Center PC 3.1; .NET CLR 1.1.4322)
Remote Address:
HTTP Referer:
-- Never Was Anything Great Achieved, Without Danger --
D3AN is offline
