SailNet Community - View Single Post - Starting an Atomic 4 after heavy snows
post #4 of Old 11-23-2010
QuickMick
QuickMick's Avatar
you may want to see if you have a heat exchange unit. iirc not all a4 setups do, and you want to make sure that both; during the winterizing process you heat ex was drained of h20 (as freeezing temps can break a seam=yanking and brazing) and that the fluids are replaced after thaw.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
