SailNet Community - View Single Post - Start rule question different fleets
post #8 of Old 11-25-2010
US27inKS
Midwest Puddle Pirate
US27inKS's Avatar
It actually made more sense before. If you were both on Port, you should have been going from the start pin to the committee boat (at least that's how we alway set it up). In either case this is not a Port/Starboard issue as both boats are on the same tack. This is a windward/leeward case and Boat B is wrong. Starboard trumps Port and Leeward trumps Windward. Boat A was leeward and had rights.
Just to be clear. In this scenario, was boat B running parallel to the line and boat A was close hauled trying to start? Then did Boat B cut off Boat A and force him down the line?? The only thing that could sway this in Boat B's favor is if Boat A could be seen as an overtaking vessel.
John USYacht 27 "Cora Lee"
US27inKS is offline
