SailNet Community - View Single Post - code zero vs 150 genoa
post #4 of Old 11-27-2010
davidpm
davidpm's Avatar
Originally Posted by capecodda View Post
I don't know if this will work for you, but the setup we have includes a 110 jib plus a code 0. The jib is on the furler all the time. The code 0 is on a wire luff and has a furler always attached while rolled up in the bag (like a snake). A number of companies make furlers that work this way, furling around the wire luff. In light air we hoist snake in front of the jib (our rig is fractional so there's room), and then unfurl at our leisure. If the wind pipes up, we furl the code 0, unfurl the jib, and keep going. We drop the snake again, at our leisure, mostly back on the hook at the end of the day. =
Can you jibe the boat with the code 0 out or do you furl, jibe then unfurl?
What about sheets for the code 0 are they on deck at all times so you have two sets of sheets out all the time?
What model furler are you using for the code 0?
davidpm is offline
