SailNet Community - View Single Post - Swing Keel or Fixed Wing Keel? Catalina 22 or 25?
post #8 of Old 07-11-2006
sailingdog
Is the 2600 lbs. the dry weight of the boat, or the weight of the boat loaded with equipment, gear, food, gas, and water? If the former, then you're probably about 800 pounds light on the weight.
The trailer is probably about 1000 lbs. as a rough guess based on the size and weight of my trailer. That means you might be as high as 4400 lbs for the trailer and boat.
Yes, surge brakes can be added to a trailer, but you're much better off having them installed by the trailer manufacturer. The surge brakes need to have a different trailer yoke installed and the brake drums still have to be added...which might be more than you want to do. It is also significantly cheaper to have the factory add brakes than it is to do it as an after market modification.
sailingdog is offline
