No, it doesn't get that warm. Water has a very high heat capacity, and it only heats a few degrees above ambient when used in a heat exchanger for an AC unit. Certainly not at a temperature where the difference would be useful to heat water.
I'd point out that the additional resistance of the heat exchanger coil in the hot water heater would also put a strain on the raw water
pump for your A/C system, and that most are undersized as it is and would lead to them failing sooner.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
