Old 07-12-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Originally Posted by Rickm505
I use the 3 anchor system Kanter promotes, each set 120 degrees from each other and the rode to each led to one common point in the center of the 'star' they create. A 20 foot bridle from each bow is attached to this point. The boat is stable, and the anchors hold. I've used it with 3 Fortress and it's dependable when 50/50 chain and 5/8" 3 stand Nylon at 10:1 is shackled to each anchor, and run to the center of the star.
Rick in Florida
Hey Rick-
Unless I'm reading his post wrong, he is actually advocating two anchors at 180 degrees apart port and starboard with one perpendicular to it off the bow, not a star formation as you're proposing. He's also using three different rodes and a bridle to just the bow anchor from what I see, as well as different scopes on the anchors—7:1 for the port and starboard, and 10:1 for the bow.
So you're comparing apples to oranges. He's also using three different anchor types, not three matched ones.
If you're new to the Sailnet Forums... please read this POST.
