The bear's two cents worth
You can find those old cast iron irons at antique shops in the states. A lot of people use then for door stops and they will run from $5.00 up depending on condition and size. Don't get too big they get quickly heavy as they get bigger. Also being cast iron they will rust but using steel wool or fine sandpaper can usually clear most of this up and using a good old brown paper bag between the iron and the cloth works too. Be carefull heating the iron up of
stove eyes. They are usually solid cast iron and the handle will get very hot if you let it. A pot holder helps. The iron has no temperture control but the learning curve is not to difficult to master here again brown bag will help prevent scorching but be carefull with synthetics.
