SailNet Community - View Single Post - Mast Step Plate
Thread: Mast Step Plate
post #5 of Old 12-10-2010
mike dryver
Sailingweb if the heads of the screws fit properly then they are the right size. just pull one if you have not already done so and check shank diam to hole diam. a mast step is in compression load not shear load unless a stay or shroud fails
mike dryver is offline
