SailNet Community - View Single Post - The sail back
Thread: The sail back
post #6 of Old 12-17-2010 Thread Starter
71Irwin32
71Irwin32's Avatar
The A4 on my boat is virtually brand new removed and sent to Moyer Marine for rebuild and updating, but then the boat sat mostly unattended about 3 years allowing the teak to leak and eventually causing a major short in one of the main wiring loops. Originally I figured I rewire the whole boat and will eventually, but I can in the mean time, isolate just the engine wiring so I can get it running and charging the secondary batteries I installed....gas cleaned out and filter, oil change. That's all it needs. The compression showed 115 psi on all 4 cylinders and the spark is excellent. Maybe a carb rebuild, but I already have all that stuff sent from Moyer.
...but the outboard worked fine in chop up to nearly 3'.
71Irwin32 is offline
