SailNet Community - View Single Post - Stockton, Ca. to Oakland, Ca.
post #3 of Old 12-26-2010
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Years ago, I did some fisheries survey work in the Bay/Delta region; mostly on a 42' trawler. We sampled from Big Break and Rio Vista, downstream throughout the rest of the Delta and Bay.
A few points to think about (that may all be obvious, anyway):
- this time of year it's often easier to make such a trip than it is during the summer (those afternoon Delta "breezes" can make westward progress almost impossible);
- if you do get a stiff west wind, you might as well find a harbor (or anchor in a side slough) -- if there's an ebb tide set against the wind, the steep wave faces will pound the Bejeezus out of you and your boat -- if you have a flood tide working with the wind, you probably won't make any progress anyway;
- there are plenty of hide-e-holes in side sloughs, behind little islands, et cetera; take a good anchor and a rode with a couple of boat lengths of chain, in case you have to wait out any bad weather;
- the bottom is ever-changing, DON'T trust your charts in areas with any hint of shoaling -- particularly the area around the Sacramento/San Joaquin convergence (but, really anywhere);
- Once you get down into the Bay (below Vallejo), the tide shouldn't be nearly the problem that it is in the Delta/Suisun Bay/Carquinez Straight; between Antioch and Mare Island is the area you'll have to deal with tides the most (basically, that part of the trip where you'll be using the Suisun Bay chart).
SlowButSteady is offline
