Old 12-28-2010
centaursailor's Avatar
centaursailor centaursailor is offline
Senior in age only!!!
centaursailor is on a distinguished road
Thumbs up
[QUOTE=Nemesis1;677703]Setting the anchor slowly by letting the wind blow you back on it is a good idea,I snub the Rhode a few times as I let it out to help it set. Some times there isn't enough wind to set the anchor so backing down on it slowly, is the only way to set it. Once you get it to hold, back down with more power to test it. If it pulls out it wasn't set properly. Pull it up and do it again. I use 1400 rpm on a 38ft sail boat to test the set. It is always a good idea to dive on the anchor to make sure it is dug in properly.
Dave[/QUOTE]
Yep, anchoring is a tricky business. The tips I,v learned is to be generous with the scope and always back up under engine to test the set. My spade sets well most bottoms, sand, mud and even shingle. The oul fisherman's catches in everything else. The anchor alarm on the GPS gives extra confidence but a couple of steady transits can,t be beat for a good nights sleep.
Happy sailing.
Brian
P S have had a lot of freezing with the reply function but seem to have cracked it by turning of images in the tools tab and Java.
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
