SailNet Community - View Single Post - Running the outboard out of the water for 30 seconds
post #2 of Old 12-28-2010
tommays
tommays's Avatar
It KILLS the water pump in about 11 seconds more or less
MUCH better to use a tall 5 gallon bucket or the correct ear muffs to keep the pump wet as it will self drain if the motor is level
IF you winterize it and drain the fuel bowl there is no need to do anything over the winter BUT the motor would like a cover as it helps a lot with the UV also
Most do have a drain screw for this reason
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
