I think the issue is how close hauled to the wind a boat can make effective headway compared to another which seems to be the IP weak point.
If you need to sail someplace upwind and your tacking 15 degrees lower its takes a LOT longer.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
