SailNet Community - View Single Post - Island Packet 35
post #10 of Old 12-31-2010
olson34
Lightbulb There's a customer for Every Boat
Jeff has said it well.
I would only add that, like all boats power and sail, you have to consider first the 'design brief' for a given design, or in this case an entire line of boats.
IP wanted a fairly high-end quality shoal-draft hull with a lot of interior room for living. From that came a long keel with a protected area for prop and rudder in case of groundings, given the shoal cruising areas intended.
Basically it is a trawler hull form with a sail plan above. The fact that it sails poorly is just the reality of that whole design package.
If you sail in deeper waters where you can enjoy the benefits of an efficient keel form and want a hull form intended first for sailing... then you ought to consider another brand of boat.
They are nice enough boats, but you just have to know your real needs.
LB
olson34 is offline
