My J24 mast is about .095 wall and will hold #10-24 screws and as long as you use stuff life tef-gel they will come in and out
IMHP 10-24 is better than 10-32 for this type of stuff
If you feel the load is really high then you can make a plate with 4 screw holes and mount the clutch to it and then use 4 screws or rivets to hold the plate to the mast
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
