SailNet Community - View Single Post - yanmar alternator wiring....help!
post #7 of Old 01-04-2011
mitiempo
mitiempo's Avatar
FarCry
An alternator uses about 1 hp/25 amps output. 105 amps is about max for a single belt according to Balmar and others. Right at the limit all around but workable.
It could be wired so it can be switched off when max power is needed for propulsion or it could be installed with a regulator that allows the output to be dialed back to say 80% - that way it would run cooler as well.
Brian
mitiempo is offline
