SailNet Community - View Single Post - vacuum sealer recommendations
post #7 of Old 01-06-2011
onremlop
I am on my third one in about 10 years and my recommendation is to get the most expensive one you can find. My first one was a small convenient one that could not adequately suck all the air out and it would just run and run until I manually stopped it. The second, more expensive one did the same. The last good bigger one has been working quite well.
I use the more expensive bags for long-term food storage and non-food related items. The items I use short-term I use the cheap-knockoff thinner bags.
If you plan on re-sealing something again and again, make the bags bigger because when you open them and re-seal them, you lose about an inch or two. I have learned not to make the bags too small since it makes it hard to seal when you don't have enough room to lock the bag.
I only re-use them if there is no raw meat or ingredients in there. Salmonella is not fun.
"If it is going to happen, it's going to happen out there." Cap'n Ron.
onremlop is offline
