SailNet Community - View Single Post - Anchor talk - Old vs. New Generation
post #4 of Old 01-06-2011
sailingdog
I'd point out that if the CQR, Bruce, Claw, etc., were all that effective, there would have been no need for the newer, more effective designs. I'd also point out that given the very wide breadth of boat designs, anchoring philosophies and requirements, that what may be perfectly satisfactory for one person may not suit another at all.
For instance, I don't believe in the idea that you should be carrying a "storm" anchor. I believe that your primary anchor should be sufficient for any reasonable, or even slightly unreasonable, storm condition you might run across. The reason I don't believe in carrying a storm anchor, is that by the time you realize you may need to deploy it, the conditions have usually deteriorated to the point where deploying it could present a risk to you or your boat. If the primary anchor is properly sized to handle storms, then you don't need to deploy one if the weather turns for the worse.
sailingdog is offline
