SailNet Community - View Single Post - Suggestions for a fuel pump?
post #3 of Old 01-07-2011
sailingdog
I would setup the fuel polishing system separate from the regular engine fuel supply. How large a pump you would need depends a lot on how much fuel you're talking about.
Originally Posted by Capnblu View Post
I would like to know which 12v fuel pump you would suggest that would provide enough GPM to polish my fuel through a dual Racor setup. I intend to configure the plumbing so that this pump acts as a lift pump while running the engine. The engine is a 4-108 with the regular low, and high pressure pumps on the engine.
sailingdog is offline
