SailNet Community - View Single Post - Good news: Pac garbage patch much smaller
post #10 of Old 01-07-2011
Bilgewater
Hmmm
Bilgewater's Avatar
John, good post.
This is a paragraph taken from the article:
Another way to look at it, White said, is to compare the amount of plastic found to the amount of water in which it was found. “If we were to filter the surface area of the ocean equivalent to a football field in waters having the highest concentration (of plastic) ever recorded,” she said, “the amount of plastic recovered would not even extend to the 1-inch line.”
It sounds like if you seined a football field size patch (very fine mesh) 1 foot deep you would end up with 160' X 1' X 1" of plastic. But what do they mean by surface? If you seined it 20' deep, I would think it would be much less plastic per sq ft.
As you likely know I'm constantly having to go through a great deal of misleading information regarding our ocean environment, so this interests me.
Also...our football fields are 195' wide, so it's a bit misleading for Canadians. Our football field would likely include areas of less concentration.
Impulse III
Truant Pilothouse
Bilgewater is offline
