SailNet Community - View Single Post - Suggestions for a fuel pump?
post #8 of Old 01-08-2011
noelex77
There are 2 types of polishing 1 uses a high flow rate to blast the tank walls. This requires that the outlet is moved around the tank to scrub the tank walls. (like hosing down a driveway). This type of polishing is done occasionally (every couple of years) and requires opening up the tank to work well. It is usually done by a commercial operator, but you can DIY.
The second type of polishing is done often (maybe everyday) is lower volume and works best when the tank is agitated by boat movement .
In my reading and experience both types of polishing systems can work well.
Commercial operators can only offer the first type of polishing and often imply this is the only option.
noelex77 is offline
