SailNet Community - View Single Post - Insulation: Reflectix or Sheet Styrofoam
post #6 of Old 01-10-2011
sailingdog
Another option is to use regular closed-cell foam insulation and then laminate mylar "space blanket" to the inner surface to provide additional insulation. I'd point out that most of the plastic/foam insulation will produce toxic fumes if burned. Cork is a better choice if you want to avoid toxic fumes. Aerogel is a good insulator, but expensive and difficult to work with.
sailingdog is offline
