SailNet Community - View Single Post - Overheating Perkins 4-108
post #7 of Old 07-20-2006
eaudela
Originally Posted by Eleanna
Engine is newly rebuilt but is overheating, the mecanic was going crazy because he couldn't find anything wrong with the engine. I ended up taking the boat out of the marina ($70.00/hr)....
Q. would a bad prop cause overheating?
Reason for asking is when i increase the rpm the rudder shakes, i went under the boat to see but i'm such a lousy diver so i didn't have enough time to really see the prop.
I'm thankful for any responses.
E.
Eleana...I had heating problem too. If you have a water heater on bord,
each time you add water to the engine you have to fill the hose at the water tank with water because the new heather tank have a valve , if there is air in the hose the valve won t open and the engine is overeathing. You will have you install a bypass valve to let the water go back to the engine.
the temperature in tank is 142 F. a lot less than the engine EAUDELA
eaudela is offline
