SailNet Community - View Single Post - Reverse only partially engaging
post #2 of Old 01-12-2011
Faster
I've had similar situation with a Hurth gear.. it seemed the cam on the shift lever didn't fully engage the slider that moved the plates internally. I removed the lever/cam assembly and had a welder build up the cam a bit and it worked for years again after that....
Different gear, though...
Faster is offline
