SailNet Community - View Single Post - oil in air intake
post #2 of Old 01-13-2011
Minnewaska
Of all that work, bleeding the fuel lines is probably the most likely, IMHO. Try again?
Do you mean the oil breather is dripping oil? That's not terribly uncommon if it's a very little. If a notable amount, you may have blockage or blow by in the cylinders. If she ran well very recently and before you began this work, I would doubt either. Can I assume you are certain you didn't overfill the oil?
Edit: did you flip a compression release lever intentionally to bleed or by accident?
Minnewaska is offline
