SailNet Community - View Single Post - About to buy a N33 -- getting cold feet?
post #18 of Old 01-18-2011 Thread Starter
sailorpilot
Thanks, I'll look more closely at the rubber. Did you pull out all of the rubber in chunks, or just the part to the sides of the plexi? Seems like if you pull it all out, there would be nothing to set the plexi position in the groove. There's a polyurathane sealant called Sikaflex that's used for mounting car windows that experimental aircraft builders use for mounting plexi canopies that I'm thinking might work well for this.
sailorpilot is offline
