SailNet Community - View Single Post - Need trailer for Columbia 26
post #2 of Old 01-23-2011
RXBOT
You are going to need a better than 6000 pounds trailer. I would say a minimum of two 3500# axles. If you have a cradle it could simply go on a flat deck used or rental. If you have no cradle then you will likely have to modify a used trailer or build from scratch. If you plan on storing on the hard every winter it would probably be worth building a trailer then you could store it at home and have easy access for working on it.
RXBOT is offline
