SailNet Community - View Single Post - Dangers of LED navigation lights
post #8 of Old 01-25-2011
Maine Sail
Maine Sail's Avatar
Originally Posted by BubbleheadMd View Post
I understand that the USCG will certify a light based on it's brightness, arc of visibility, and color spectrum, but NOWHERE in the COLREGS can I find a reference to color spectrum beyond the words "white, yellow, red, green" etc.
The standards by which nav lights are built is published in the CFR (Code of Federal Regulations). You, as a used boat owner, are NOT required to have "certified" nav lights or install them UNLESS you are a boat builder or re-seller/broker/dealer. If you buy a new boat in the US it WILL have certified nav lights or the builder broke federal regulations.
If you are a builder you must use USCG/ABYC A-16 nav lights properly installed and placed for proper visibility. All USCG certified or ABYC A-16 lights will meet the minimum standards as set forth by the CFR. This is what labs like IMANNA use when testing nav lights to USCG/CFR nav light standards..
______
-Maine Sail / CS-36T
Maine Sail is offline
