SailNet Community - View Single Post - Cal 21 Keel
Thread: Cal 21 Keel
post #5 of Old 01-31-2011 Thread Starter
sailnova
sailnova's Avatar
I started in on the keel pin over the weekend and have a few photos to share. We took out a lot of soggy plywood from the center of the cabin to get a good look at the keel pin. In order to access the keel pin we had to remove fiberglass from around the pin...and this is what we found. Both sides have a wooden housing or "block" that is surface attached to the fiberglass. I do not know if this is original. The starboard side (photo) block is in two pieces but the port side is a single piece...next step???
sailnova is offline
