SailNet Community - View Single Post - Air, Water or Air / Water Cooled Refer Condensor
post #6 of Old 02-01-2011
nickmerc
nickmerc's Avatar
Plus water can carry more energy than air. To back that up the manual on my AB cold plate suggests water cooling for warmer climates. Also, in the winter you will notice that if you run a humidifier, either whole house or in the room with the thermostat, the furnace will have longer off times.
I run mine on air cooling in cooler weather then turn on the water cooling in addition to the air when it gets warm.
________
GLASS PIPE
nickmerc is offline
