If you're going to use heat, use hot water, rather than a heat gun or other heating technique. When you're re-bedding the new frame, use Butyl Tape rather than another sealant or adhesive, provided the
hatch frame is through-bolted. Silicone-based sealants have very few legitimate uses on a boat.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
