SailNet Community - View Single Post - Repair Cracked Teak Toe Rail
post #3 of Old 02-02-2011 Thread Starter
casey1999
casey1999's Avatar
I do not have photos. The cracks and voids that need to be filled are cosmetic. Talking with the boat builder the toe rail only prevents you from slipping off the boat. The toe rail does not hold the deck/hull joint together. Apparently the deck/hull is glassed and may have additional blots that are located under the toe rail. From what I understand the toe rail could be removed without effecting the hull/deck structure (although the bolt holes would need to be filled. Boat is an S&S 34 built in Austrailia.
casey1999 is offline
