SailNet Community - View Single Post - Uses for Chart plotters and chart plotting software
post #24 of Old 02-03-2011
sailingdog
You can use MacENC to setup the waypoints and routes and then export them to the Garmin.
Originally Posted by HeartsContent View Post
I have a Garmin 541s that I bought in March 2010 and agree with many of the post here. There are times when it is spot on and there are times when it's not even close. Less the latter though and the problem is clearly that the charts are inaccurate.
Not really sure how to keep this device and its built-in charts up-to-date as there appears to be no mechanism to do this from Garmin.
Really do not like Garmin's Home Port application and prefer MacENC and the NOAA charts instead.
The most interesting use of the Garmin is it's track feature that I have used to follow a previous pass through an area. In the end, I really don't understand how to use all the features of the Garmin or it's just really limited for functions of storing and maintaing tracks.
I tried using Home Port to plan a trip and found that Active Captain and other online resources were much more valuable.
sailingdog is offline
