SailNet Community - View Single Post - 2 bank battery charger acting weird
post #3 of Old 02-03-2011
sailingdog
What size are Bank1 and Bank2. If bank 2 is the starting bank, it may very well not need much of a charge, and drop quickly into float mode. If bank 1 is the large house bank and it is heavily used, the charger is far more likely to need to stay in bulk charge mode for a while, until the bank gets to 80-85% SOC and then will slowly drop voltage and amperage as the battery bank's ability to accept current drops.
What make/model is the charger? What size are the battery banks? BTW, as Stu points out, the charger's negative lead doesn't have to go to the batteries, but should be lead to the ground bus bar/post for the boat's 12 VDC system.
sailingdog is offline
