SailNet Community - View Single Post - Running Rigging Questions
post #3 of Old 02-04-2011
sailingdog
Amsteel could be used, but it might slip in the clutches, as the line is very slick. Dynex Dux is designed for standing rigging and has no place in running rigging, and is specifically heat-treated to help reduce creep.
Do you have dacron sails? If so, then going with T-900 or another spectra/dyneema-cored line might be overkill for your sheets. You could use it for the halyards to minimize weight aloft and give you more of a safety margin on the halyards.
Cajun Trading Company has pre-packaged halyard/sheet kits for many common boats at a pretty good price. The kit for the Catalina 30 looks like this:
That kit is using XLE, which is their version of a polyester double braid, similar to StaSet, which is not a low-stretch line by any means.
Using a light dyneema/spectra-cored line for the spinnaker sheets or genny sheets makes sense, since a lighter line would help the sail keep its shape better in light air conditions. Spectra and its cousin Dyneema don't absorb water and are lighter/stronger than polyester.
sailingdog is offline
