SailNet Community - View Single Post - Sending GX2150 AIS NMEA data to chart plotter over Bluetooth
post #4 of Old 02-05-2011
Waterman480
The problem with this is that the AIS data will also be passed to the baud rate converter, thus causing the overflow if you are in a high AIS use area, which the Delaware is.
Also on the GX2100 - GPS data is not repeated on the AIS data line - I don't know if this is rectified on the GX2150. I have a GX2100 with a GPF300i - they play very well together, but it is a pain to have to run two serial lines to the computer to get both AIS and GPS data.
Waterman480 is offline
