I want to start off right on my 1981 O'Day 34's
fuel system. Actually all the systems but the
fuel one is the current one of concern.
When I purchased her the
fuel tank (30 gal)was leaking. I've had a new one built for her by the original tank manufacturer (Flordia Marine Tanks, nice people). And will install it this weekend.
If you were starting with a new diesel
fuel system what would you do besides installing new primary and secondary filters? I have new hoses from the supply and return side of the tank and will also replace the fill and vent hoses.
Are there any additives that I should use initially and continue to use?
Is a truck stop a good source of diesel?
Should I remove the rail to have it boiled out and the injectors tested?
Scott
Karma
1981 O'Day 34
